06-03-2024
12:05 PM
09:50 AM
Camera: EOS R8
Lens: RF24–105mm F4-7.1 IS STM
On my lens body, there's a [Focus/Control] switch. If I switch it to "Focus", I expect auto focus to stop on my camera, and I can turn the focus ring to manual focus. (this is the behavior when I use my old EF lens with adapter ring on the same camera body).
However, what actually happens is, auto focus still works, and turning the focus ring does nothing. I tried Av, Tv, M, etc, there's no difference.
Is there anything else I need to do?
06-03-2024 12:17 PM
One of Ken Rockwell's complaints about the R system.
You have to set the manual focus mode in a camera menu:
"By default, there is no always-responsive instant manual-focus override as we take for granted in our DSLRs.
EOS R cameras need a menu setting changed for manual-focus override, otherwise the focus ring is always ignored in AF.
Find the "Lens electronic AF" option in your AF menu (AF 4 in EOS R5 or CAMERA 8 in EOS RP), and set it to either "One‑Shot‑>enabled" or "One‑Shot‑>enabled (magnify)."
Now manual focus override works if you turn the ring while continuing to hold the shutter halfway, but only after focus locks in ONE SHOT."
06-03-2024 12:17 PM
06-03-2024 01:08 PM
Can confirm this is the right answer. Thank you!
