04-11-2024
09:55 AM
02:08 PM
A friend of mine was lucky enough to have received her Canon RF 200-800mm lens that she had ordered in Nov. 2023. She has encountered an issue with the lens design. The new lens does not appear to allow use of a filter while the lens hood is in place. She and her camera shop have tried a number of different brands of filters, but none appear to allow the lens hood to be mounted while a filter is attached. This seems to be a rather inexcusable design flaw on Canon's part. When Canon technical support was contacted, no one appeared to know anything about the issue. With the exception of this problem, she loves her new lens. Has anyone else encountered this issue with this lens?
07-07-2024 10:25 PM
I may have found the answer. Both users reporting issues have the "Promaster"
The thread size is 95mm, the outside diameter is 100mm (thats +5mm) and the frame is 8.2mm tall. The light transmission is 98.2. I'd return or exchange it.
04-11-2024 10:34 AM
I don't have the lens but unless she wants to use a polarizer, filters are almost obsolete. I understand wanting to use a polarizer with the hood on would be an problem, though.
However, even a polarizer is becoming less and less relevant.
04-11-2024 10:46 AM - edited 04-11-2024 10:49 AM
Your/Hers is the only mention I've heard of. The lens accepts a 95mm filter. I don't own one yet, but based appearance and documentation there isn't a reason why the 2 couldn't be used together. You can put a lens cap on as well it you want to reach in there with your fingers or just turn the hood around and mount backwards. I could see it being a problem if you were using a filter with a large or oversized frame/ring that changed the O.D. of the lens at its face.
If you mean that the hood doesn't have a retractable hood slot for filter adjustment, then yes, this lens was not intended for use with that type of filter. Thats not a design flaw. If you happen to find a post or reference about this on the web, I'd be interested in seeing it.
Worth noting, if you rent one from LensRentals, it comes fitted with a 95mm Hoya EVO filter and its hood.
04-11-2024 12:59 PM
Rick, my friend is just trying to put a normal clear or UV filter on the lens. None of brands of 95mm filters tried would allow the lens hood to be mounted after the filter was screwed into place. My wife and I own many Canon lenses and have never before encountered this issue with any of them. I am still awaiting an order for the RF 200-800 lens for my wife and was curious if anyone else had experienced this issue.
04-11-2024 10:26 PM
I'm planning to put one on mine eventually as well. 😀 I haven't ordered yet, so you'll probably get her's before I see mine. I have never encountered an issue like this either. I know a few people I can ask. Let me check.
04-12-2024 03:46 AM - edited 04-12-2024 03:49 AM
Welcome to the Canon Forums!
Sorry to hear you are having issues with such a coveted lens. I do have a couple of questions that no one seems to have asked, yet.
Could you describe EXACTLY why or how the hood or lens do not fit/work together? For example, does the hood not fit over the filter?
Where did you order the lens? Was it a Canon Factory Authorized dealer?
What brand and model of lens filter are you using?
What brand and model of lens hood are you using? The Canon ET-101 should have come with it.
This is from the B&H web site. This is a small sampling of recommended accessories.
04-12-2024 07:48 AM
My friend's issue is that once a filter has been screwed into the front of the lens, the Canon-supplied hood does not have enough clearance and cannot be attached to the lens. I do not know which brands or models of filters were tried. When she discovered the issue with a filter that she had purchased, she returned to the authorized Canon dealer. The dealer tried a number of different brands/models of filters, but none would allow the supplied Canon lens hood to fit over them. She also later met with a Canon Representative who was visiting the store for some type of sales promotion. The Canon Rep had no answers for her regarding the hood/filter issue. I have had the same lens on order since last November from B&H Photo but have no idea when or if it will ever be shipped to me! Last month, when I had to send in my Canon EF 100-400 L Lens to Canon for service, I also asked the technical support rep if he knew anything about the hood/filter issue on the RF 200-800 lens. He was unaware of the problem. So, I decided to post the issue on this forum to see if any other owner of the lens had experienced the same issue.
04-24-2024 04:45 AM
Any update on the topic? Can it be the reason why shipment are so slow?
Here in Europe it appears to be in pre-order forever..... with a long list....
04-24-2024 05:57 AM
I have found no other information regarding the hood/filter issue. I was hoping a current owner would respond here or on B&H Photo's page for the new lens. I did find one other reported issue. One RF 200-800 lens owner reported that the lens would not securely mount onto his Canon EOS R3 body. Here is a link to his video. Bing Videos. Perhaps Canon is trying to quietly fix these issues, but no one at Canon support seems to acknowledge them.
04-24-2024 12:15 PM
You still have not told us what brand and model filter is causing you issues. In fact, you have yet to confirm what hood you have.
