01-05-2022 06:00 AM
Hello,
I have read that the rf15-35mm has ibis wobble when zoomed out. I don't have that lens, but I got the RF24-70 and it seems it also suffers from ibis wobble at 24mm. Is this normal?
01-05-2022 02:52 PM
What am I supposed to be looking at in the video? It looks and sounds like several seconds of handheld video, which was shot on a fairly windy night.
01-05-2022 02:57 PM - edited 01-05-2022 02:57 PM
Sorry forgot to mention that part. Have a look at the buildings on the far left.
01-06-2022 04:44 AM - edited 01-06-2022 04:45 AM
I saw that. It is a handheld shot. I do not see anything that strikes me as unusual. If you have Digital IS turned on, then the image may get cropped slightly.
01-06-2022 09:16 AM
While true that some stabilization systems crop the image, that's not what is being shown in the video. The buildings on the left-hand-side indeed have a wobble (jell-o) effect going on. A shaky hand-held shot no doubt causes it's own set of issues, but this is an additional problem above and beyond.
01-06-2022 09:29 AM
Yes, I don't have Digital IS turned on, just Lens IS + IBIS. Apparently, after doing some research the wobble is caused by IBIS. And it seems the majority of people who reported are using RF15-35 trying to shoot wide-angle below 20mm. I'm just trying see if my gear has problem or it's working as expected.
01-05-2022 04:46 PM - edited 01-05-2022 04:47 PM
I don't have any equipment with IBIS (the EOS C70 uses either lens IS and/or digital stabilization), so don't have first-hand experience. I can state though that for the specific equipment itself, I'm not a fan of any non-optical solution. I do like the different rigs you can get which seem to offer much better (and sometimes superior) stabilization solutions.
01-07-2022 06:55 AM - edited 01-07-2022 06:58 AM
It is shot in the dark, using a wide angle lens, possibly without any specific part of the image for a stable AF lock. Just what exactly should the IBIS be locked onto? As near as I can tell, nothing. The OP reports this only happens at the wide end of the lens, 24mm. It s working normally, IMHO.
01-13-2022 08:50 AM
This is interesting. I don't see this mentioned anywhere; but for IBIS to work it needs AF lock? How would you do that?
