11-24-2023 05:56 PM - last edited on 11-24-2023 06:16 PM by Tiffany
Hello I brought a rebel t7 and I wanted to know if its compatible with a 70-200mm and 24-70mm canon lenses.
11-24-2023 06:11 PM - edited 11-24-2023 06:12 PM
Yes. Both EF lens intended for full frame will mount and can be used on your T7
Please note the following. The 24-70 will yield a equivalent field of view of 38-112mm, and the 70-200 FOV equivalent of 112- 320mm.
~CarePaks Are Worth It
11-24-2023 08:04 PM - edited 11-26-2023 08:11 PM
Yes but make sure the prefix says EF and NOT RF.
11-25-2023 04:47 AM - edited 11-25-2023 04:48 AM
I’ve always found this chart to be informative, but a bit overwhelming if you are not able to read and understand it. Lotsa fine print this time, too.
If the OP has a T7, then which row should the look at, and which columns in that row?
11-26-2023 08:18 PM
The row that says APS-C DSLR in light blue. The top columns are used for Mount & lens type are color coded. EOS DSLR Full Frame/ EOS AF SLR, EOS R series APS-C & Full Frame rows are also color coded. They can be ignored in this case since the OP has a Rebel T7. So that is not applicable to them.
