12-27-2022
08:15 AM
08:37 AM
My e72 ii lens cap doesn't seem to be fitting my rf 24-240 even thought it's filter thread size is also 72. Anyone know the reason/solution? Any help would be appreciated, thank you!
12-28-2022 05:59 AM
Is that a filter mounted on the lens?
12-28-2022 04:52 AM
12-28-2022 05:14 AM
Is your lens cap upside down? The second image above appears to be the side that should face the lens. The white letters “Canon” should be facing away from the lens.
12-28-2022 07:11 AM
Just showing the words in the back
12-28-2022 05:59 AM
12-28-2022 07:14 AM
Not a filter but had to double check the lens, there was a 72mm to 67mm adapter!
12-28-2022 10:05 AM
" there was a 72mm to 67mm adapter!"
Gotta ask how did it get on the lens?
