12-27-2022
08:15 AM
08:37 AM
My e72 ii lens cap doesn't seem to be fitting my rf 24-240 even thought it's filter thread size is also 72. Anyone know the reason/solution? Any help would be appreciated, thank you!
12-28-2022 05:59 AM
Is that a filter mounted on the lens?
12-27-2022 08:53 AM
Canon lists it as compatible. Any evidence of damage to filter thread on lens or the lens cap?
12-27-2022 11:23 AM - edited 12-27-2022 11:25 AM
My questions might be, is the lens cap you are using the one that came with the lens? and Do you have a filter installed on the lens that might have changed the depth or diameter?
12-27-2022 11:29 AM
My e72 ii lens cap doesn't seem to be fitting my rf 24-240 ..."
Isn't it the lens cap that came with the lens?
12-27-2022 08:00 PM
There seems to be no damage to any threads. The lens cap doesn't fit at all
12-27-2022 08:01 PM
There is no filter installed and the lens cap is the same one that comes with the lens
12-27-2022 08:03 PM
It is but it just doesn't fit. There seem to be no logical way to make it because the part of the lens cap that sits in the filter threads of the lens is bigger
12-27-2022 08:33 PM
Squeeze the two tabs in the center of the lens cap. That will retract the gripping part so that it will insert into the thread region. Then release and the cap will be gripped by the threads.
12-28-2022 04:49 AM
That is what I have been doing, does not work.
12-28-2022 04:52 AM
