03-28-2013 05:37 PM
I don't seem to be able to source a 67mm closeup lens for my 60D even though Canon claims to have one. Is there an acceptible option?
Thanx
03-28-2013 08:18 PM
You can use a step down ring (72mm-67mm) with a 72mm close-up lens.
However, you should consider investing in extension tubes instead. They are generally cheaper and without IQ degradation.
For magnification factors and focus distance, check this link out:
http://www.bobatkins.com/photography/eosfaq/closeup.htm
03-29-2013 01:05 AM
03-29-2013 07:44 AM
03-29-2013 07:51 AM
I use extension tubes with prime lenses but prefer close up lenses with zoom lenses because with extension tubes your focus changes with zooming. So, if you're really close, whenever you zoom a bit you've got to move your setup to refocus.
03-29-2013 08:27 AM
03-29-2013 11:40 AM
@fdnave wrote:
Great point Thanx, I think I'll go wit Hoya at this point, any thoughts?
The step up ring from 67 to 72 would be a good option so you could use the 500D. But as long as a third party option is a 2 element, coated lens it probably will perform well. I'm not familiar with all the options as I use the 500D.
03-28-2013 08:21 PM
I don't know anything about how well they work but besises using a step up ring there are choices available.
http://www.bhphotovideo.com/c/search?atclk=Circular+Sizes_67mm&ci=158&N=4207499338+4294955266
03-29-2013 07:41 AM
03-29-2013 03:11 AM
Or use one or more extension tubes (no glass - fits between the lens and the body). Allows closer focusing. Canon tubes cost a bit but are excellent quality. Others have had good luck with third party brands.
