06-21-2022 08:48 PM
When I am panning while taking video with my 70-200 (on the 1D X Mk III), the image stabilization will briefly stick or get "caught up" and will then jolt forward, instead of smoothly stabilizing as I pan. Sometimes it is so bad that I can feel it getting stuck with my hands as I film. This has only happened recently and occurs no matter what my cameras settings are. I will attach a video of this happening while I am panning. I have tried both IS mode 1 and 2 and neither seem to make any difference. (Starts to get really bad at 7 seconds)
06-21-2022 09:09 PM
I have seen this too on some lenses, but only when the IS "revs up". IS units can certainly go bad. I suggest sending it back to Canon.
06-23-2022 10:53 AM
You best course of action is to send camera and lens to Canon for a C&C. Include a description of the issue you are seeing.
06-23-2022 11:07 AM - edited 06-23-2022 11:09 AM
@jberg44,
Can you share your video settings with us?
What video mode and frame rate were you shooting with?
You mentioned all modes. Is that correct?
06-23-2022 11:38 AM
This clip was shot in 1080p at 120fps, IS was on mode 2.
Yes, this happens in all modes with various settings/frame rates unfortunately
I was recently in a sandy environment and there was a lot of loose dust in the air so I wouldn’t be surprised if that caused it.
06-23-2022 11:38 AM
Yeah I was thinking the same thing, best to get it fixed before it hinders production
06-26-2022 05:40 PM
If you have Movie Digital IS enabled, try turning it off. The option does not appear in all still?movie shooting modes.
07-11-2022 10:56 AM
So I turned off the cameras movie digital IS and it seemed to fix the issue, so should I send the camera out to get checked?
