04-10-2021 04:28 PM
04-14-2021 11:23 AM - edited 04-14-2021 11:24 AM
And I totally misread your comment 🤦♂️
RF to EF isn't physically possible. It's something I asked about when the EOS R was launched. The flange on the RF mount is so much larger (54mm), and it has 12 pins with more circuitry in the lenses that the EF mount won't understand. The EF mount is backward compatible with the RF mount using the adapter, but it won't work the other way around. Sorry
04-16-2021 10:42 PM
04-17-2021 09:55 AM
"... if an amateur uses an EOS 1D X Mk IIi or a R5 does that make that user a professional photographer?"
No, it does not.
"Does the basic camera that Ansel Adams used to take his landscape photos make him an amateur photographer?"
No, it does not.
"Where does "not pro level" end and "yes pro level" begin?"
It begins and ends with the design, build and construction of the camera and/or gear. A simple comparison of a Rebel and a 1 series should make it blatantly obvious but apparently it isn't so obvious to some.
"Can someone be a professional photographer if they don't own a Canon L Series lens to take their pictures?"
Yes, they can! The big difference is, pro level gear is designed to be used day in and day out for years without issue. It is designed to be there, depended to be there, when the job is started. It has nothing to do with the talent level of the person.
Canon will make a 1 series mirrorless R camera. When is the only question. They are getting close now, very close.
04-17-2021 10:02 AM
" It's amazing how professional photographers managed before such cutting edge technology existed."
Not really ever hear of the F1 and F1n or the Nikon F3 as examples?
Perhaps the Graflex.........
