05-16-2023 04:03 PM
Canon EF 24-70 L fails to autofocus at 70mm.
5D MkIV body.
Not the same problem as losing focus at different focal lengths, which is well documented here.
With the lens set to AF, lens will focus at all focal lengths until I turn to the maximum magnification...fully counter-clockwise. This is on a tripod without moving the camera relative to the subject. In other words, at 24mm autofocus beeps, but going to the max it will not autofocus, even if I move the body slightly to put different objects in the path of the AF points.
If I turn the zoom ring clockwise, just slightly below 70mm, then autofocus works again. I don't remember this being normal behavior.
I cleaned the lens and camera contacts, but no improvement. In fact it does the same thing on a T3i body.
Any thoughts? I can live with it now that I know the workaround, but is it a defect?
cheers
05-16-2023 04:57 PM
Which version of the 24-70mm lens do you have version 1 or 2. It sounds like the flex cable in the lens may be starting to fail.
05-17-2023 10:55 AM
version 1, not v2
05-17-2023 07:10 PM
The flex cable is on the way out. V1 of the lens had this problem.
05-18-2023 09:24 AM
Thanks!
Is it repairable if I send it to Canon - do they still do repairs?
05-18-2023 09:52 AM
No not anymore. You can send it to a 3rd Party for repair. Or look into replacement if the repair costs exceed the value of the lens.
05-18-2023 09:53 AM
You would have to check with Canon to see if version 1 is still repairable, if not a third party shop could likely do so.
With the zoom ring set at 70mm, does manual focusing result in proper focus? Hopefully the issue is electrical and not mechanical.
I am still using the 24-70 I bought back in 2005. I have thought several times about grabbing the newer version but I am a bit concerned given the reported failures with it given that my current 24-70 has been perfectly reliable.
Rodger
05-18-2023 10:04 AM
yes, manual focusing works fine
05-18-2023 11:00 AM - edited 05-18-2023 11:00 AM
Not sure if the v1 is still under repair support. Register in your My Canon account to see support options. If its not, you can contact midwestcamera dot com. They are a authorized Canon repair agent and should be able to do this for you fast and reasonably.
~R5 C (1.0.5.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10
~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
