09-23-2013 03:04 PM
Do you use the 100-400mm in combination with 2x extender ? What do you think about this combination ?
11-28-2018 05:11 AM
11-28-2018 05:16 AM
11-28-2018 05:17 AM
11-08-2019 10:01 PM
I don't have tha Canon Extender yet but I did try the the Canon 100-400mm L II with a Kenko 2x (manually focused). As long as the shot can wait for me, focusing manually gives me decent results. As good as the 400 alone... no, but I do get usable images with that combination. Hand held shot @400mm +Kenko 2X. The original image is 18megs but reduced down to 5 megs which is the limit to upload.
What I found that is helpful (for me) in manual focus mode is to rough focus to the distance, press the shutter 1/2 way down to engage image stability and complet the focus while engaged, and complete the shot. I am able to nail the focus repeatedly by doing this.
11-09-2019 10:12 AM
@Rx_Mich wrote:I don't have tha Canon Extender yet but I did try the the Canon 100-400mm L II with a Kenko 2x (manually focused). As long as the shot can wait for me, focusing manually gives me decent results. As good as the 400 alone... no, but I do get usable images with that combination. Hand held shot @400mm +Kenko 2X. The original image is 18megs but reduced down to 5 megs which is the limit to upload.
Does your Kenko 2x actually communicate with the lens?
What is the camera displaying as an Aperture value when you use it?
If the lens were communicating with the body, then I would have expected a lens error message.
11-09-2019 01:58 PM
This was shot at f/11. That seems to be the sweet spot for clarity with or without the Kenko.
11-09-2019 02:01 PM
The Kenko passes through all camera commands. (focus, image stability, f/setting, and meta data. The auto focus is just about useless except in very bright conditions. I put the lens in manual focus mode but all other functions are operating properly.
11-24-2019 10:00 AM
I picked up the EF 100-400 f/4-5.6L just recently and I'm loving it. The thought of 2x more reach even with the aperture/light penalty is apealling. I have a 5D Mark III, but I'm not sure of its auto focusing ability cranked out to 800. Likely a stationary target and a tripod for manual focusing is the best bet at this setting.
Taken at 400mm, f/9, 1/1600 sec, iso-100
11-24-2019 10:27 AM
The shot I took was hand held, manual focus. If you engage image stability during focusing is like having it on a tripod.
11-24-2019 11:42 AM
" If you engage image stability during focusing is like having it on a tripod."
It all depends on what your standards are and what results are pleasing to you. If you are happy with that shot, great. Personally I would not be.
