Canon 1.4 teleconverter
LesWurse
Enthusiast
 Will Canon's 1.4 teleconverter be compatible with an EFS 55/250 zoom lens on my 60D?
18 REPLIES 18
jrhoffman75
No it's not.
Thanks - that saves me $350!
...where did you find it for $350?
PJ
(Grampy)
"Photography is a money-sucking black hole, and I'm approaching the event horizon"
Used with a E+ rating at Adorama.com
...guess I don't know what an E+ rating is - for me Adorama shows $429...
PJ
(Grampy)
The $349 price was under "used lenses".  E+ rating in "Adoramaese" means better than average for a used item.  There was a used Canon 2.0 teleconverter listed also but I've been warned off of them.
In any event, my EFS 55-250 lens won't accept any teleconverters so I have no inexpensive way to reach the 400MM I'm looking for.
"... I have no inexpensive way to reach the 400MM I'm looking for."
Well that isn't exactly true!  Smiley Happy
There is a 400mm, 500mm and 600mm fully manual lens made that is sold under several brand names.  They all sell for less than $150 bucks.  Much less on the used market.  I have seen them used for $35. Are they great lenses?  Well I suppose you know that answer but they are serviceable. I had, probably still do have, most of them from back in the film days.  I don't think they have changed a bit since then.
Big question do they work?  Yes, they work.  They do make a usable picture if you don't get too critical about it.  They are fully manual.  They are pre-set but you focus with it wide open.  They are all T-mount and it usually comes with the lens so mounting to your camera is no problem.  If you should go used make sure it is the right T-mount.
Good info - I'll add this to my research on Kenko teleconverters. I would really like to get up to 400mm on my 60D w/o it costing an arm and a leg.
Thanks - I should have said "There is no inexpensive way to reach the quality 400mm lens I wanting.  But isn't that the case with just about everything!?
Avatar
