12-25-2024
12:16 PM
12:21 PM
I damaged my Canon EFS 55-250mm lens. Should I attempt to repair it or purchase a Canon EF 75-300mm lens ($160.00) for my EOS Rebel T3?
12-25-2024 12:47 PM - edited 12-25-2024 12:52 PM
Not sure what the extent of the "damage" is, but the lens itself can be replaced used for $100 and new for $250.
I'm inclined to tell you to replace it with a used copy.
The EF 75-300 is a low quality, entry level optic. You'd be much better off with the EF 70-300 USM II. It can be had used as well.
12-26-2024 09:15 AM - edited 12-26-2024 09:16 AM
Where is the damage?I've repaired lenses in the past so may be able to tell you whether its worth trying.
Also Rick is right about 75-300 lens.It isnt very good.I very much prefer the 55-250
12-26-2024 10:33 AM
Always check the used market before you decide on repair or replace or upgrade. You must know the prices unless you don't care and just want a certain lens. As to which you will have to make that decision. I know a lot of people that are perfectly happy with their ef 75-300mm. A lot of the Rebel kits came with that lens so there is a lot of them around. In my DSLR 101 classes it was the most common tele zoom I saw as most of those folks bought Rebels.
Are there better choices, yes, but is the "better" going to be a thing for you and how you do photography.
12-26-2024 02:19 PM
Thanks much. I am always reticent about buying anything used, but I’ll keep this option open. Do you know whether the ef 75-300mm has image stabilization?
12-26-2024 02:22 PM
The auto-focus no longer works. The lens works fine on manual-focus.
12-26-2024 06:12 PM
Ok.To repair that i think it would need a lot of disassembly.It wouldn't be easy
12-26-2024 06:21 PM
No, the EF75-300mm lens doesnt have Image stabilization
12-26-2024 07:01 PM
Ouch. I like image stabilization. Thanks for the info.
12-26-2024 07:02 PM
Which means it might be a bit expensive. Thanks for narrowing my options.
