08-07-2020 07:02 PM
I am facing IQ issues with all photos I am capturing with my 70-200 on a 5dm4. Even when mounted on a tripod under good lighting conditions, I can't seem to get crisp photos. They come out pretty soft. I am not sure if its my technique or if there is some issue with the lens. I've never had any luck with this lens since I bought it but I always attribted that to my T2i. I sent it to canon for repair few months back and they told me there is dust on the glass and the mount has scratches, which I think is total BS as I hardly used the lens.
Even after coming back from the "repair", I still get very soft pics. I will test the lens for front and back focussing to see if that's the reason, but sometimes I seem to be getting ok shots. I am not sure if I am expecting too much out of this lens. Reading online many people attest to the quality of the lens. May be I got a bad one.
Any suggestions on how I can make sure its not the lens that defective?
Link to some raw files - https://photos.app.goo.gl/mXL3rNktA21e1f2P8.
Thanks!
08-08-2020 04:17 PM
OK then you are not actually viewing at 100% pixel level. That was my point.
08-08-2020 10:58 AM
08-08-2020 12:33 PM
The link you have does not contain any Raw files. Just jpg with all the exif data stripped.
What exactly do you see wrong with this shot?
It looks pretty darn good ot me. "...they told me there is dust on the glass ..." Unless it is severe, dust on the lens will not reduce IQ.
"Any suggestions on how I can make sure its not the lens that defective?"
If your lens took that photo, there is nothing wrong with it. You might let me have a look at the actual Raw file.
08-08-2020 12:54 PM
08-08-2020 12:57 PM
08-08-2020 01:16 PM
Yes they would be so that is out. You need something like Dropbox.
However form the sample, I did get to see in PS, your lens looks just fine. Don't go beyond 100% in viewing. That is a critical viewing level for sure. If you shoot Raw format none of your camera settings are applied to the Raw file. Always do a lens correction and a small amount of sharpening. Less is more. I always do a levels adjustment in PS, too. But that is mostly it.
There are similar adjustments in DPP4.
08-08-2020 01:21 PM
