re scanner
butterflyer8000
I have a canon pixma mg2522 am running win 8.1 and tonight I could not use my Scanner it gave no error code all it said was Printer is in use but there is nothing in the que. Please help, as I need to scan documents to fax them. I already checked to see if  the plugs were loose but they are not. it shows the printer is there, I am out of ink right now but that is the only issue. I checked to also see if I needed new Drivers and they are all up to Date. Thank you for any help!
4 REPLIES 4
ArthurJ
Hi butterflyer8000,
It sounds like the print spooler in your computer needs to be restarted. Please follow these steps to try and restart the print spooler:
  • Make sure your printer is turned on.
  • Hold down the WINDOWS KEY on your keyboard and then tap the "R" key. This will cause a box to open on your screen.
  • Type "services.msc" into the box and then click Enter.
  • After a few seconds another box will open with a list of services.
  • Scroll down to "Print Spooler."
  • Right-click "Print Spooler" and select "Stop." A small progress box will appear for a few seconds and then vanish.
  • Right-click "Print Spooler" again and select "Start."
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
an error came up after I followed instructions Code:2,140,21 please help it did not fix it!
Hi butterflyer8000,
If the printer is out of ink, the low ink error will prevent the printer from operating. You can try holding the stop button down on the printer for 5 seconds to clear the low ink error state the printer is in. If that does not work, you would need to replace the ink cartridges to resume normal operation of the printer.
yes Thank you that little thing fixed my issue!!!!
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
08/31/2022: New firmware version 1.1.1 is available forRF 70-200mm L IS USM
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
