09-07-2014 01:49 PM
my MAC does not show the "draft" print option for the mg3520. How do I enable that option?
09-24-2014 02:24 PM
Hi SAMMG3520,
To print draft, please follow these steps:
Load paper on the machine
Select the printer
Select your model from the Printer list in the Print Dialog.
NoteClick Show Details (
(the disclosure triangle)) to switch the Setup window to the detailed display.
Select the paper size
For Paper Size, select the paper size to be used.
If necessary, set the number of copies, the pages to be printed, and the orientation.
Select Quality & Media from the pop-up menu
Select the media type
For Media Type, select the same paper type loaded in the machine.
Select the print quality
For Print Quality, select High, Standard, or Draft according to your purpose.
ImportantThe print quality settings that can be selected may differ depending on a printing profile.
Complete the setup
Click Print.
When you execute print, the document will be printed in accordance with the type and size of the media.
