09-10-2015 05:51 PM
I have just finished a scan from my canon 450 into my laptop. I am attempting another scan but it is not registering as 'on' in my laptop. I have tried changing ports and putting it off and on, but it still won't show as 'on' in my laptop.
09-12-2015 09:19 PM
Hello.
If you have the MP450, make sure that the printer is connected directly to your computer via USB. Avoid using any extension devices or hubs when making the connection.
If you continue to have difficulties, find more help at Contact Us.
09-13-2015 09:45 PM
Seems that there are 2 separate machines listed on my laptop for the Canon. One says fax and the other says series. If I open 'scan' from the one that says fax, it will scan. Not sure why it shows as two. On my older laptop, it only shows as one. But, I can get it to work, so, good enough. Thanks for your help.
09-10-2015 05:57 PM
Hi!
To ensure the most accurate information is provided, we will need to know the version of Windows or Mac in use.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
09-10-2015 07:02 PM
window 7
Thank You!!
09-12-2015 09:19 PM
Hello.
09-13-2015 09:45 PM
