04-26-2021 07:01 PM
Printer Pixma G4210
I am TRYING to install my printer. The ink has leaked everywhere - the desk under the printer, nearby objects, the floor, my hands (SMURF blue). I filled the refillable cartridges to the top because the arrows on the front indicated that's what I should do. How can I stop/prevent this? -- Will the printer work with half filled cartridges? While I was searching for the product code I tipped the printer on it's side so I could check the bottom
Trouble code 6000 - appeared on the printer menu which is for a paper jam. There was no paper in printer. So I added paper and still got Code 6000. And yes I put the paper in correctly. I turned printer OFF/ON several times, reinstalled from disk twice, unplugged power cord. I still got the same error code
I had difficulty installing with a wireless connection so I switched to disk installation
Files installed on computer from disk:
One of the files "autorun' has the following code:
; AUTORUN.INF
[autorun]
open=Msetup4.exe
icon=.\WIN\res\bitmap\canon_cd.ico
[DeviceInstall]
DriverPath=WIN\Driver
[DeviceInstall.amd64]
The other installed file is 'MSETUP.checksum.' which contains the files: .exe, .dll, .ini, .bmp
04-27-2021 10:26 AM
The printer is never intended to be tipped or tilted onto its side. Especially once you have put ink in it.
Instructions for refilling is here:
Canon Knowledge Base - Refilling Ink Tanks - G4210
Brand new printer - If you have Ink everywhere, the tanks were overfilled, or might be due to tipping it on its side. I'd concentrate on cleaning things up before worrying about installing the printer.
Error 6000 is a general error - Not necessarily a paper jam:
Canon : PIXMA Manuals : G4000 series : 6000
Ink spilled inside the machine can cause other problems.
The information you listed are not errors, these are the content of files on the printers installation media. You'll need to get the printer into a functional state, (able to turn on without errors) before you can proceed. Even if unintentional, you may have damaged the printer.
~R5C (1.0.1.1) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 3080Ti FTW3 Ultra
~ImageClass MF644Cdw ~Pixel6 ~6D2 (v1.1.1) retiring
05-04-2021 04:06 PM
Hello,
I recommend you contact Canon support at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST excluding holidays.
You will need to have a Canon account when you call. If you have not created account, please click HERE:
