02-09-2017 07:34 AM
I have a MG5750 printer and I am using a mac with maverick operatign system
I want to print a PDF in balck and white. on palin paper, it does this but it has been using the small black ink tank not the large bulk inktank.
How can I force the pritner to use the large tank?
02-09-2017 01:50 PM
Hello.
In some cases, PDF files or web-based items may not be true black and white. In these situations, the printers will use combinations of the color inks or the small black ink tanks to produce the output.
Ensure that the media type is set to plain paper on your computer. If the issue persists, try printing from another program o see if this helps.
If additional assistance is needed, find more help at Contact Us.
