02-08-2014 02:07 AM
how do I print in black without using my color ink on my pixma mx 922 printer?
01-27-2018 05:22 PM
worked for me
thank you!
01-29-2018 01:53 AM
01-29-2018 10:21 PM
Does that option still use color ink? That's the issue. I print in greyscale and it turns out that that still uses color ink cartridges.
02-16-2018 07:51 PM
03-25-2018 09:16 PM
Hey,
Is there a way to override the function that if you print using duplex it prints in colour? Doesn't make sense to me that if you want print on both sides of the paper you have to use colour ink, thats really counterintuative .
Thanks
04-02-2018 02:26 PM
Not sure this is correct. Just done a long print run on my MG7751... set in grayscale mode... printing continuously for about 500 pages... and the colored cartridges have emptied. And when they do, if you click continue, the printing gets very pale even though the black cartridge is full
Yes, grayscale printing uses your color ink and no way round it that I can see.
04-03-2018 02:16 PM
Thanks, My issue seemed to correct itself. In my printer box, drop down menu for printer select there were somehow 2 printers there, both with the same name, but when I switched to the other setting the B&W box came back. Works great, when selected everything, text and images print in B&W with good quality, not in greyscale.
10-29-2018 01:26 AM
10-29-2018 01:51 AM - edited 11-01-2018 09:54 AM
12-10-2018 01:50 PM
My mac uis running Mac OS Mojave version 10.14.1
My printer is
Canon MX920 series:
Status: Idle
Print Server: Local
Driver Version: 2.0
Default: Yes
System Printer Sharing: No
Shared: No
URI: dnssd://Canon%20MX920%20series._ipp._tcp.local./?uuid=00000000-0000-1000-8000-00BBC11FA592
PPD: Canon MX920 series-AirPrint
PPD File Version: 2.0
PostScript Version: (3010.000) 0
CUPS Version: 2.2.9 (cups-462.9)
Scanning support: Yes
Scanning app (bundleID path): -
Scanning app version: -
Scanner UUID: 23F51F00-0000-0000-0000-000000000000
Printer Commands: none
AirPrint Version: 1.2
URF Version: 1.2
Added: Monday, December 10, 2018 at 12:26:27 PM Eastern Standard Time
CUPS filters:
image/jpeg: processed in printer
image/urf: processed in printer
Fax support: No
PDEs:
Hose can I use just the large black ink source to print?
