Canon Pixmar MG2520
Can this printer be set up to print labels? Im trying to figuer out how to set it up to print a 2" X 4" Label sheet. Any help will be great.
Hi I just purchased a MG2900 and when printing it will on print the header and nothing esle. Can someone tell me how to fix it? THanksAaron
Hello, I was wondering if this is a usual occurance and how can I fix it?Both the 221BK and 220PGBK will not release ink/print.I have cleaned, aligned etc and the other wells are working and these two are not. I just spent $120 for new ink cartriges ...
Ink on printed lines of documents started to disappear. I cleaned using "regular" setting twice and deep cleaned once. After cleaning, test page printed out fine and showed colors and black now all OK. However, when I attempted to print a new docu...
When I try to print or copy with A4 paper in the feed tray I get the error message:"Fed paper size is different from paper size in print settings"The printer will print if I change the paper size in print settings to "Letter" but then the copy or pri...
My Pixma MG5650 is since a few months ago requesting to update the firmware. I might consider allowing such a risky operation, but to evaluate I need to read the firmware changes. What will the new firmware bring and add to enhance the printer? Anyon...
Owned a Canon MX-922 printer for about a year This printer performs some kind of repititive maintenance cycle before and after EVERY spooled print job. I can wait 2 minutes between jobs and it will start one of these cycles again before the new job p...
I'm new to this. When printing from my iPhone over my local network. Trying to print a photo. How does the iPhone know what size paper is in the printer and also know the orientation of the paper in the printer?
Printer is brand new out of the box. I didn't get the ink cartridges in correctly, which shouldn't be a big deal. But the print head will not return to the proper position for cartridge removal/loading. It is not jammed - the head moves back and f...
I have two MG7520 printers that will not retain the printer preferences. One is connected via USB cable and the other via Ethernet cable. I am using Windows 10 on two separate PCs (each PC has a dedicated MG7520). Does anyone know the solution to th...
I seem to have the opposite problem of every search returned on scanning. My setup includes network'd win10 PC and MX922 multifunction printer. I would like to scan multiple 1-page documents (using the adf), and have them save into their own individu...
When I print text in black, everything is smuddged. When I change to a colour, the print comes out perfectly. When I print out the test pattern for my Pixma MG7150, all colours are fine. However the PGBK top grid comes out with the central portion sm...
Hi, Bought an MG3170 printer -with cartridges CL-741 & PG-740- while living in Asia. Moved to Europe in the mean time and in need for cartridges: the 74x-series are not available here. Can I use the CL-541 & PC-540 cartridges in the MG3170 printer i...
Unfortunately the Owners Manual grew legs.. Unfortunately attempting to Scan / Print Off something, Printer just spits out a Blank Page.. The Ink Cartridges were changed out recently.. Help Appreciated, Cheers Thanks..
I have this printer set up to my desktop.I would like to also set it up to my laptop.Im unable to set it up withe the start up disc,as it cannot find settings.Also tried manual as well.I have disabilities, and it would be easir for me,to use printer ...
| Subject | Author | Posted |
| 09-08-2026 09:55 PM | ||
| 09-08-2026 05:31 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM |
