04-11-2018 02:14 PM
I'm trying to install a Canon MG3620 on my Windows 10 network. I was able to install it via my laptop on my wireless network and that works fine. I'm trying to do the same on my desktop via a wired connection to the same network (same range of IP addresses). During the installation process the printer is correctly detected, but during the install WP drivers portion, this fails with the "New port could not be created: 0000" error. Retrying does no good. Trying via the administrator account gives the same error. Turning off Defender and the Firewall gives the same error, Rebooting does no good.
Thing is, once upon a time this worked just fine, but I had to temporarily move the printer to another network in another location where all devices were wireless. After some fiddling, I got all devices to recognize and use the printer there. But, when I brought the printer back home, I was only able to get the printer working by using my wireless laptop. My wred desktop gives the port could not be created error.
Can anyone help? This is driving me nuts...
Thanks
02-18-2020 08:04 AM
I don't have the original disk can someone email me the CNMNPU file ?
02-21-2020 01:32 PM
08-28-2020 09:05 PM
09-01-2020 04:52 PM
Please refer to my solution (Skullrubble) from the previous page. Unfortunately, my printer is different from yours. Can you go somewhere, maybe a library, to see if they have computers with CD drives? Maybe a friend? Even Best Buy may help you; after all, you just need the one file (CNMNPU.EXE) transferred to a flash drive.
09-28-2020 04:35 PM
Just discovered that the CNMNPU.EXE file you're looking for is inside the driver you're likely downloading from the Canon website. I found it in the Canon driver file (mp68-win-mx920-1_01-ea32_2.exe) file under the LAN folder. Just open the .exe file in your preferred Unzip utility and extract the LAN folder to your hard drive. You should be able to run CNMNPU.exe from there, without the worry that someone sends you something else in a private message that you shouldnt install.
02-19-2021 06:02 PM
I'm trying to re-install a Canon MG3620 on my Windows 10 network and I keep getting the same message. I can't do what others have done because I don't have anywhere to play the CD. I went through the same thing when I first installed it and got a work around but I dondf't rmember what it was. System will not allow me to delete ports either with or without the print spooler running. I have removed the installation download and reinstalled - always same thing. Help!
02-20-2021 08:07 PM
Read the post above your own (by jzrubbish) for a possible solution. Alternately, you could buy a cheap external CD/DVD drive.
04-21-2021 09:25 PM
Your fix worked! I've been trying off and on for a year to get my printer to work remotely from this computer. But I was afraid I would lose the two other computers which use this printer. All is well; all three computers work remotely to my printer. To find the path to CNMNPU, I used the canon start up disk in my 😧 drive. The address I used is D:win\driver\LAN\cnmnpu.
So happy, thank you,
Doug
08-08-2022 06:46 PM
Hi Jemmer,
I have the mg3620 as well and it used to work but after moving to a new house, I can't get it to work. I uninstalled the drivers with the hopes of reinstalling from scratch but now run into the same error new port could not be created. I don't have a cd-rom on my laptop and don't have the installation cd either. Can you send me a copy of the CNMNPU.exe file? I downloaded the full driver from canon website and unzipped the file but can't find it inside. Can someone point me to it's location or send me a copy of the CNMNPU.exe file?
thanks.
08-09-2022 02:25 PM
I'm not sure how to send a file in this forum and then I'm not I have the latest version. But, you can google the file CNMNPU.EXE. One hit I found suggested going to the Canon site-> Support and enter your printer model, then select Driver downloads. Get the full package and download it. The file that gets downloaded is a .exe file. Rename it to .Zip and then open it. you will find the CNMNPU.exe in one of the directories in there (/LAN ?). You can then extract it and put it somewhere to use.
Good luck.
