10-29-2022 03:16 PM
As snowbirds, we leave for months at a time each year. I'm interested in knowing what procedures we should be using for our printers while we are away for extended periods. Do I leave them on? Remove ink cartridges?
Every year I have to worry about clogged print heads, damage to printers, etc., even though we have whole house surge protectors. This time our power and internet went up and down multiple times during a hurricane while we were away.
11-01-2022 01:19 PM
If you are not going to use the printer for a long period of time, we recommend taking the ink cartridges out of the machine and storing them in a sealed ziplock bag. This will help prevent the clogging or drying up of the ink. When you go to use the printer again, you will need to install the ink cartridges and perform several print head cleanings.
Also, you can power off the printer. Please be advised that after that long period of time with the printer being off, you may need to reconnect the printer back to your network when you return.
11-01-2022 04:46 PM
A great idea, but how do I get the cartridges out? This model printer will only allow you to remove a cartridge when it is empty. Is there a way to fool the programming so I can remove them?
11-01-2022 05:05 PM
Can you post the model identification of the printer?
11-01-2022 05:33 PM
Sorry I thought you would see the model number from my profile. It’s MB2720. Thanks for getting back to me
