09-01-2018 12:10 AM
The TS6020 thinks I've loaded and selected A4 paper in the cassette when I've actually loaded and selected letter size paper. The printer therefore will not print from the cassette. It only uses the rear tray.
09-01-2018 09:50 AM
Hello.
Double check to make sure that the correct paper source is being selected before printing from your computer. It may be possible that the rear tray is being selected in the settings on the computer.
If you continue to have difficulties, find more help at Contact Us.
09-01-2018 09:50 AM
Hello.
