11-14-2019 03:51 PM
Cannot scan using printer buttons. Works fine to copy and print. When trying to scan on printer, get message
"set Printer to start Scanning" I can scan from the computer by going into the scan utility.
This is a new computer.
11-14-2019 04:01 PM
Hi gtownann!
Thanks for posting in the Canon Forums!
To have a better understanding of your issue, please let everyone know what operating system you are using (Windows 7/8/10 or Mac OS X 10._).
If this is a time-sensitive matter, our US-based technical support team can help HERE
Thanks!
12-08-2019 10:15 AM
My Canon TR8520 used to work proprly - now all I get is "set pc to printing" ------- I have a macbook pro, macOSmojave, version: 10.14.6. This is serious - where is the answer?????? Nothing posted to date has worked, thanx, Jack3
12-09-2019 04:05 PM
Hi Jack3,
Please follow these steps:
1. Please click one time on the desktop so that "Finder" appears in the upper left corner.
2. To the right of Finder, click on GO and then Applications.
3. In the Applications folder, please click on the IJ Scan Utility folder and then the IJ Scan Utility to open that application.
4. Place an item face down on the scan glass.
5. Click the PHOTO button on the IJ Scan Utility.
Are you able to scan?
12-16-2019 07:37 AM
I did find a somewhat acceptable response by using the 'System Preference' tool to get into PTR, but I still could not print a multi page doc.
I took PTR offline/off network - reloaded PTR software and then reconnected PTR to my net. Problem solved. Thanx for the teams suggestions and help. Jack3
03-30-2020 12:45 PM
What does PTR stand for?
03-30-2020 12:44 PM
Hi, When I click once on the desktop, nothing happens. I tried clicking on it twice. I tried right clicking on it. Nothing happens. Where else can I find the "Finder" thing? I could press Start from my scanner this morning, but now I can't. Why is this?? I get to where I'm supposed to choose black or color, and then I get this set the PC to start scanning message, with no instructions on what that means, why it's now showing up, or what to do about it. Thanks for any help!
03-30-2020 12:48 PM
I have Windows 10. Am I also supposed to have something called Finger on my desktop? What would be the instructions for fixing this Set the PC to start scanning error on a Windows 10 OS? Thanks again!
03-30-2020 01:19 PM
Hello, melimeg!
Welcome to the Canon Forums!
The above answers are referring to macOS. Since you're on Windows 10, your instructions will be different.
The Forums aren't intended for immediate assistance. If your question is of an urgent nature,click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside of the USA, please click HERE to find your support options.
03-30-2020 01:37 PM
Thank you! Do you have a set of the Windows 10 instructions that you could post here?
