04-15-2019 08:01 AM
I’m sure this question has been posted many times before but unfortunately I can’t find one. I just bought this printer & I’m going thru the steps to hook it up, and nothing I try is working. The desktop is not recognizing the printer wirelessly. Looking thru some of the articles on the Canon site, one of them said both the computer and printer need to be on the same WiFi network in order for them to connect, so maybe that’s the problem - but if so, there are no instructions to connect the printer to the WiFi network. Any help would be greatly appreciated.
Thanks,
Andy
04-24-2019 03:53 AM
Hello ABecker,
If the Easy Connect method is not working for you the Manual Connect may be an easier method. Click HERE for information on connecting the printer to the network using the Manual Connect method. Click HERE for information on connecting the printer to the Windows OS. Click HERE for information on connecting the printer to the Mac OS.
04-15-2019 10:05 AM
@Andy,
Maybe this will help. It's located on the support page for your printer.
~R5C (1.0.1.1) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 3080Ti FTW3 Ultra
~ImageClass MF644Cdw ~Pixel6 ~6D2 (v1.1.1) retiring
04-24-2019 03:53 AM
Hello ABecker,
04-24-2019 07:05 AM
Thanks to both of you for the advice. The other night I did try the manual method, used the IP address and it worked!
01-20-2021 02:54 PM
I have a TR8620. I also have an EERO PRO 6. I had WPA3 turned on - I had to turn it off to get the printer to work.
