02-19-2014 04:10 PM - last edited on 12-01-2022 12:41 PM by Danny
Hello,
I have a Canon D480 on Windows 7 using Omni Page 18..1
When I bring up the toolbox and check the threshold I am always at 72.
I want a deeper scan somewhere in the 120-140 range.
I also scan legal and letter sizes through the ADF.
I can set the threshold manually for a certain size and it stays but when I switch to another
paper size it defaults back to 72.
Any ideas?
Thanks in advance.
I do have to set the machine to USB scanning mode before I use the application.It seems to default to network scan,(very silly default)
02-22-2014 02:08 PM
Hi Longbid!
I understand that this issue is frustrating. You can save the [Threshold] setting under [Favorite Settings] of the ScanGear MF Tool. When you select "Advanced Mode", click the drop-down for [Favorite Settings], then select "User Defined". Adjust the settings and then click the green [Scan] button. Now, whenever you scan, select "User Defined" and you should only have to change the paper size.
I hope this information is helpful to you. Should you need further assistance, please contact us at 1-800-OK -CANON (1-800-652-2666). Have a good day.
02-23-2014 10:09 AM
Patricia,
Thanks for the effort but this is what I have now.
Whenever I change the paper size I default back to 72 (even though the advanced states user-defined).
Oh well just a thought.
Maybe the coders can come up with a better Toolbox.
Cordially,
Mike
12-16-2021 10:41 AM
This still does not work. You would think that it would have been fixed by 2021 (since the answer is from 2014). A threshold of 72 doesn't scan jack. The lines on my papers, the words I have written...all disappear when I scan at this level. Could you please, Please, PLEASE fix this? And only one setting? "User Defined"? How about letting us save different settings for different jobs? (Brother has this, though they started forcing dates or numbers at the end of file names, so I bought Canon thinking you wouldn't insist on adding something to the end of the file names but, alas, I was wrong...a third party software allows me to name the file what I want to without adding extra stuff to the end...another issue Canon and Brother need to address.)
Please, for the love of Pete, start making user-friendly interfaces. Sheesh.
