09-04-2019 12:43 AM
I am trying to print a binder cover sheet that has a photo on it along with type. It is 8x11 regular printer paper and using the lower cassette. It prints the type but the photo will not print. I have put in new ink cartridges. HELP!!!
09-04-2019 08:31 AM
Hi, samma2327!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
09-04-2019 09:16 AM
09-04-2019 11:04 AM
Hi samma2327,
Please print the nozzle check pattern to determine whether the ink is ejecting properly from the print head. To do this, please follow these steps:
1. Make sure that your PIXMA MX922 is turned on.
2. Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
3. Open the Paper Output Tray and then open the Output Tray Extension.
4. To print the nozzle check pattern:
4-1. Press the MENU button on your PIXMA MX922.
4-2. Use the down arrow key until the wrench and screwdriver icon is selected, then press OK.
4-3. Select Maintenance, then press the OK button. The Maintenance screen is displayed.
4-4. Select Print nozzle check pattern and then press the OK button. The pattern print confirmation screen is displayed.
4-5. Select Yes and then press the OK button.
The nozzle check pattern is printed and the pattern confirmation screens are displayed alternately. Please compare your printout to the example that has been attached to the bottom of this post.
If they differ, perform a few cleanings. Please perform the following steps to perform a Cleaning:
3. Select Maintenance then press the OK button.
4. Select Cleaning and press OK.
5. Press OK to select Yes.
The cleaning will be performed. After 2 or 3 cleanings, print another test page.
Does the test page print correctly?
09-04-2019 11:06 AM
09-06-2019 01:22 PM
Hi samma2327,
Did the test page that you printed match the example that I provided?
09-06-2019 01:38 PM
09-09-2019 02:39 PM
Hi samma2327,
since the nozzle check printed correctly, I will need to gather some more information. Please reply with the answers to the following:
09-09-2019 05:29 PM
