05-04-2024
08:38 PM
10:21 PM
Tiffany
My pixma cannon printer keeps throwing a code of 1651 error code. When I try to print
06-24-2024 11:14 AM
To begin troubleshooting, please open the printer and look at the ink cartridge labels. If you see the letters PPP on the ink cartridges, please check your Canon Account and make sure that you are still enrolled in the PIXMA Print Plan. The PPP inks will cause the printer to produce the 1651 error if the PIXMA Print Plan has been cancelled.
If you are using PPP inks and you cancelled your plan, you do have the option of enrolling again. Once you are re-enrolled, the PPP inks will start working again. It may take a few hours for the enrollment to be processed.
If you have PPP inks and you do not want to activate the PIXMA Print Plan, you will need to get a new set of ink cartridges that are not part of the program. The ink cartridges sold at retailer are not part of the program. You can also purchase regular cartridges from Canon Direct at this link:
https://www.usa.canon.com/shop/ink-toner
If you do have PPP inks and you are enrolled actively in the PIXMA Print Plan, I recommend reaching out to Canon support. You will need to register your Canon gear HERE to access additional support options.
10-13-2024 06:33 AM
I had this same thing happen to me a couple of days ago when I tried to print. For whatever reason my printer just stopped communicating with my wifi. I did all of the wifi checks and everything. Long story short, I was able to fix it today by running the master set up on my computer as if it were a new printer I was adding to it. Since it still has the same serial number, it still linked up with my print plan and was finally able to communicate the ink/printer info so I can print again. It is really random that it happened. I am not sure why.
