01-09-2025 05:29 PM
Is it true that on the Pixma G3270 if the printer has been inactive for a long time (and I have the Automatic ON feature enabled) it will on its own do some sort of nozzle "wiping" operation to avoid nozzle clogging?
Best regards,
Doug Kerr
01-10-2025 08:39 AM
Best regards,
Doug Kerr
I don't own that printer, but my Pro-100 does not execute any sort of cleaning function when the printer is idle.
It does go through various degrees of cleaning cycles when a print job is executed. The degree of the cleaning is related to how long the printer has been idle, but any period longer than a few days always triggers the maximum cycle.
01-10-2025 08:52 AM
Hi, John,
Thanks.
Best regards,
Doug Kerr
01-10-2025 02:36 PM
In another thread, specifically with regard to the Pixma G3270, Arthur J, "Product Expert" from Canon, wrote:
"If the printer is left on, it will do a quick clean cycle at random intervals to prevent any nozzle clogging issues. . ."
I assume that if the printer is OFF, but automatic ON is enabled, it will wake up long enough to do that.
Maybe.
Doug
01-10-2025 03:48 PM
So, if in fact the G3270 "wipes its nose" periodically, and I use it to print infrequently, do I still need to run, for example, a nozzle check print every couple of weeks to keep the nozzles from clogging?
Thanks.
Doug
01-21-2025 04:44 PM
Hi DougKerr,
It is recommended that something is printed every 10 days to 2 weeks. A nozzle check would probably be the easiest.
01-21-2025 05:07 PM
Hi, Patrick,
Thanks.
I have a "tickler" on my calendar to help me do that.
Doug
