04-18-2025
11:10 PM
03:03 PM
James_C
I've been trying to print this illustration, but all of my attempts have the line art appearing gray or light blue. For some reason, only the line art is affected while the rest of the colors look fine. I replaced the black and magenta cartridges since they were low, but the problem is still happening. What should I do?
04-21-2025 02:05 PM
Hi GenDolDesigns,
Please load plain paper into the cassette of your TS9521C and then follow these steps:
!. Turn your PIXMA TS9521C on.
2. Tap the gear icon at the bottom of your printer's display.
3. Tap Maintenance.
4. Tap Print nozzle check pattern and then Yes.
A test page will print.
Please compare your printout with the example on this page:
TS9500 series > Maintenance > Examining the Nozzle Check Pattern
If your nozzle check does not print correctly, please follow the steps on this page:
TS9500 series > Maintenance > If Printing Is Faint or Uneven > Maintenance Procedure
If you continue to have difficulties, please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your PIXMA TS9521C and then click on the Product Support button. When that page loads, click on either the Phone Support button or the Chat Support button to access support.
