PIXMA TS3522 Refilled Ink Cartridge still registers as being low
cayita03
I bought this printer second hand. I did some research and my understanding is that you can refill your ink cartridges. I have refilled them but when I put them back in (yes, these are original canon ink cartridges) the light still displays that ink is low. I have looked up every video on how to "reset" the cartridges but nothing has worked. Anybody run into this issue?
1 REPLY 1
jinaxam861
Hello! @cayita03
Canon printers often show "low ink" even after refilling original cartridges because the chip inside doesn’t reset. You can usually bypass this by holding the Stop/Reset button for 5–15 seconds when the warning appears. Some models need a specific reset sequence, and chip resetters are available for certain cartridges. If that doesn’t work, clean the chip contacts and make sure the cartridge is seated properly. You can still print despite the warning, but avoid running on empty to prevent damage.
Holiday
