02-10-2024
09:01 PM
09:43 AM
So frustrating. cannot figure out what the problem is.. says everything is working,, conected, etc,,, just shoots out blank pieces of paper..
02-10-2024 09:55 PM
Hi PinchockDave, and welcome to the Community!
To have a better understanding of your issue, please let everyone know the model number of your Canon printer and operating system on your computer. Any other details you'd like to give will only help the Community better understand your issue.
If this is a time-sensitive matter, please check out your other support options here: https://canon.us/MyCanonAccount
Thanks!
02-12-2024 04:07 PM
I have a TR8620a I believe ! am using windows 10?
02-12-2024 04:44 PM
I tried downloading new driver software; still not working...
02-14-2024 02:58 PM
Please use the steps HERE to print a nozzle check. If your nozzle check matches the example listed, the printer is working and the next step is to check the printer software.
To check the printer driver, open the control panel on your printer and then select Devices and Printers. If you see your printer listed, right click and select printer properties. In the window that opens select print test page and let us know if that page comes out blank as well.
02-14-2024 08:00 PM
I did that once and it looked good, also have done the test page. I have found that it does not like to print just black and white. If I change text to a color shade it prints.
