07-06-2013
10:41 AM
08:49 AM
I tried to print a web page wirelessly from my iPad on my canon mg 5320. I have had no problem before. Now it says error, cassette. There is no paper. Load paper then push start. I had plenty of paper loaded. I reloaded and pushed start...same message
08-25-2016 07:18 AM
08-25-2016 01:57 PM
Hello.
If you continue to have difficulties with locating the paper feed options, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
10-12-2016 04:10 AM
I have a canon mg4250. Insists I have no paper loaded. I have cleaned the roller and done as much maintenance as I can. Nothing works. This is very poor as I have an urgent printing requirement.
02-05-2017 01:42 AM
HI there, I have a brand new canon mg3660, I have printed a one page document only and it is telling me to load paper when paper is already loaded.
02-06-2017 04:34 AM
You could try these steps because they worked for me:
1. Try uninstalling all your printer drivers associated with the "problem" printer.
2. Reinstall them and retry doing a "print" job. (you may have to delete the existing print-job).
3. When asked to load paper (which is alreay loaded), press the OK button to register the paper.
It should print your assignment (mine did).
Jim Robson
(jimrobson183).
02-08-2017 01:40 AM
02-08-2017 10:42 AM
Shakay244,
Check to make sure that the tray is properly loaded into the printer before printing again.
If you continue to have difficulties, find more help at Contact Us.
02-09-2017 12:27 PM
02-10-2017 09:39 PM
Thank you for your reply but I did give you the model number mg3660 and there is no paper tray as such, you just slide the paper into the bottom of the printer. I have gone back to instruction booklet and completed everything as stated, machine still saying to load paper. This is very frustrating considering we bought the printer brand new.
02-12-2017 07:35 AM
Hi Shakay244,
The PIXMA MG3660 is not supported by Canon USA. For further assistance, it is recommended that Canon Australia is contacted. Please use the following link to email Technical Support:
https://www.canon.com.au/support/support-request-form
Or use the following number to call:
13 13 83
