04-25-2024
05:02 AM
08:17 AM
We do have problems with our Pixma G3411, it prints with white horisontal lines, but only in the black.
This is a normal document.
This is what we have tried. " more than once with no change at all"
1. running from the canon IJ Printer assistant tool
Cleaning
Deep Cleaning
Print Head Alignment
Ink flush
Bottom plate Cleaning
Roller Cleaning
Then we took out the cartridge and cleaned it.
But we do still have the same problem. Can some one please assist us what to do?
10-09-2024 04:19 PM
Hallo there. I do have the same issue. Did you find a solution to this? I would really like to know. Thank you for your time.
10-09-2024 04:21 PM
Hi there,
Are you using the same printer as the original post?
10-09-2024 04:27 PM
Thank you for the reply.
Yes, the same one.
10-09-2024 04:30 PM
Thanks for confirming that model. That appears to be a European model, so we at Canon USA don't have any resources to help with this issue. While our Community members may be able to chime in with suggestions, we are unable to offer support directly.
For support in your region, however, please check out our Global site and select your region HERE.
