PIXMA G3290 unable to see ink levels. Is there protective film over the tank windows?
lginn8510
I just purchased and set up a Canon Megatank Prisma G3290 printer. Only problem is I can't see the ink levels. Does anyone know if there is a protective film over the tank windows or are they just dark?
2 REPLIES 2
DerrickL
Whiz
Whiz
The windows look dark on this video:
https://youtu.be/gxihBGdfVZ4
This video will show you step by step how tu fully setup your Canon PIXMA MegaTank G3270 & G4770 printers from the very beginning: Install the ink and paper, How to connect to a Computer and Phone, How to print and use the scanner. Amazon Links↓↓ ➜Canon PIXMA MegaTank G3270: ...
I spoke with Cannon. They were dark because each tank was filled with ink. They said as the ink goes down i would be able to see ink levels. We'll see...
