12-15-2012 11:26 PM
Using a MG 6220, how do I center an 8 x 10 phofo on fhs page? 5 x 7 is ok, but 8 x 10 is shifted off center, Left and right margins are not the same.
Printing is with Photo Shop.
12-19-2012 10:27 AM
Hello rdbrown.
The horizontal and vertical alignments would be controlled by Photoshop.
However, if the alignment is correct on screen, it may be related to the current paper size selections. If you are actually using 8"x10" sized paper, check to make sure that "Letter" has not been selected as the paper size. The Letter paper size is 8.5"x11". Also, if Letter sized paper is being used, check to make sure that the paper size was not set to 8"x10".
If you continue to have difficulties, we recommend that you contact our support group using the "Contact Us" link below.
