Search instead for
MX490
rmbrewerwv
Please tell me what I need to do.  I bought my daughter the MX490 to use for school.  Now I find out that since it has a FINE color cartridge the black cartridge will not work when trying to print documents.  On-line and troubleshooting says that if a FINE color cartridge is installed it will only use the color cartridge and disables the black cartridge.
IS there a work around?  IS there such a thing as a regular (Unfine) color cartridge?  I need help on this.
Thanks
4 REPLIES 4
jrhoffman75
I believe if you select Plain Paper you can use the pigment black ink.
Stated the other way, you can only use the pigment ink cartridge if you select Plain Paper.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
I have tried that a couple of times.  Even changed the print settings from draft to standard to best and tried to print black only.  Still does not work.  I tried with plain paper, which is my default setting, and still no luck.  As I said above trouble shooting said if you are using a FINE color cartridge it will always go to it and not the black only cartridge.  Can I run the printer without the color cartridge?
Thanks
rmbrewerwv
Thank you so much.  I will try this tonight.  I hope it works as I have tried most everything else I can think of. I was head of an IT department for a banking institution with several locations for 30+ years.  Just think of doing this.
Thanks again
06/30/2022: Service Notice: EOS 70D: Error 70 or Error 80
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
03/22/2022: New firmware version 1.2.0 is available for PowerShot PICK
03/16/2022: New firmware version 1.5.2 is available for EOS-R5
03/16/2022: New firmware version 1.5.2 is available for EOS-R6
02/07/2022: New firmware version 1.1.1 is available for EOS-R3
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
12/7/2021: New firmware version 1.3.0 is available for Mount Adapter EF-EOS R 0.71x
12/7/2021: New firmware version 1.1.1 is available for CR-N 300
12/7/2021: New firmware version 1.1.1 is available for CR-N 500
12/2/2021: New firmware version 1.1.0 is available for RF 70-200 F4 L IS USM
