07-05-2018 11:54 AM
I have had this MG6320 Printer for several years and have never had a problem scanning to my Win10 PC. Today when I tried to scan to a PDF file, an Error Message appeared:: "The specified function is not available with the current settings. Change the following setting: FORMAT". The Format is set to PDF but I keep getting the error and it will not let me scan to a PDF file. I can scan to a jpg with no problem. Also, if I use the IJ Scan Utility, from the PC, I can scan as a PDF file. Is there some way to reset the printer that might fix the problem?
07-06-2018 04:59 PM
Hi denk47,
Re-installing the drivers should resolve the issue.
Click HERE.
Scroll down to "Recommended Drivers."
Click “Select” next to "MG6300 series MP Drivers."
Press "Download."
Open and run the file.
Follow the onscreen instructions to complete the installation.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
07-06-2018 05:41 PM
Thanks for the reply. I finally found my problem and it was cockpit error. I discovered that I had the Doc.type set to Photo rather than Document. Once I changed that, it worked fine.
