07-21-2016 02:43 PM - edited 07-21-2016 03:27 PM
I printed a few pictures on photo paper, the first few came out as expected but all of a sudden they started coming out with a strong red cast. I do not know how to correct this or why it happened in the first place, I didn't change any settings. What should I do to get my pictures to print correctly?
Adding - I tried to print regular pages and everything has gone red
07-24-2016 11:10 AM
Hi DDuyan,
First, please make sure that the ink tanks are installed in the printer correctly and are in the correct order. The order from left to right is as follows:
CLI-251 M
CLI-251 Bk
CLI-251 Y
PGI-250 PGBk
CLI-251 C
Next, a test of your PIXMA MG5520 should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MG5520 and follow these steps:
1. Select SETUP from the HOME screen on your PIXMA MG5520.
2. Rotate the menu to Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to the bottom of this message. If they differ, please perform a few printhead cleanings. To perform cleanings, please follow these steps:
3. Press <OK> on Cleaning.
5. Press <OK> on Yes.
After a few cleanings, please print another Nozzle Check.
Does the Nozzle Check print correctly?
If the Nozzle Check does not print correctly, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
