IP4700 - Blurry black text when printing but only on photo paper
pako
Hello. The problem I mention in the subject persists only on photo paper, but not on regular one.
Images and colors are of better quality when using photo paper high quality settings (as well as photo paper), as it should be, however black text is blurry, seems even a little bit bolded. It only applies to text, images are perfectly fine. What should I do?
The problem is still there when I use the photo paper settings but use regular paper instead. It is still blurry compared. Maybe it has something to do with the fact that I put photo paper in the backside of the printer and regular paper on the front, so from 2 different spots?
Thank you
0 REPLIES 0
Avatar
