08-26-2015 09:23 AM
My Canon MG5320 will not print at all. All ink cartridges are new & full, it goes through all of the motions and the paper even comes out but nothing is on it. It doesn't matter if I print from paper tray or rear paper holder. It won't print directrly from the computer it is hooked up to no via Wifi. I hate to go buy a new one when this one used to work fine. I haven't disconnected or moved it - it just stopped ????
08-26-2015 11:07 AM
08-28-2015 12:10 PM
Hello.
First, please make sure that the ink tanks are installed in the printer correctly and are in the correct order. The order from left to right is as follows:
CLI-226BK
CLI-226M
CLI-226C
PGI-225PGBK
CLI-226Y
Next, a test of the printer should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MG5320 and follow these steps:
1. Press <HOME>.
2. Rotate the menu to Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to this message.
If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
1. Press <HOME>.
3. Press <OK> on Cleaning.
5. Press <OK> on Yes.
After a few cleanings, please print another Nozzle Check.
If the printing issues persist, please contact our support group using the "Contact Us" link below for additional assistance.
