Search instead for
I have a Canon MF4350d. The scan roller at the top feed has just stopped working. What to do?
teri
I have a Canon MF4350d. This morning the paper feed went on the blink. It takes paper half way, then starts cruching it and stops for both scan and copy mode. Tried two different weights of paper, same thing. The scan/copy from the plate works ok. How do I repair the feeder? Thanks - Teri
1 REPLY 1
Naomi
Enthusiast
Hello teri!
If the scan roller stopped feeding, it sounds like the imageCLASS MF4350D may need the ADF cleaned.  Try the Knowledge Base article below:
http://bit.ly/ZYMolP
If this doesn't fix the issue, you might want to contact Technical support directly.  You can get more help through This Link.
Hope this helps!
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
08/31/2022: New firmware version 1.1.1 is available forRF 70-200mm L IS USM
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
