How to reduce the size of the pdf scanned file ?
jai
I have canon PIXMA MG2120. I am trying to scan the documents but the size is to big to attach to email. Any Idea how to reduce the size of the PDF file?
7 REPLIES 7
Karl1
Rising Star
There are two main ways to effect the file size of a scanned PDF.  The main way would be to lower the scan resolution.  For most black and white documents you should not need more then 100dpi to get a good quality PDF.  If the file size is still to large, next to the PDF file type option should be a Set button.  When you click Set, there will be radio buttons for PDF Compression.  The default is standard, and if you change it to high, it will reduce the file size.
Using the "Set" button to compact the file totally worked.  Thank you!
I am trying to reduce the PDF size for a B&W scanned from the printer. I have a Canon GX7021 printer. In the Scan Utility, there is no set button next to the PDF option.
Abigail111
Hello
 For pdf size,you can compress the pdf size if you want to reduce the size of the pdf files.
Here is the code to do it:
using System.IO;
using System.Drawing.Printing;
using RasterEdge.Imaging;
using RasterEdge.Imaging.Codec.Compression;
using RasterEdge.Imaging.PDF;
DocumentCompression.infile(@"C:\1.pdf");
DocumentCompression.Outfile(@"C:\2.pdf");
DocumentEncoder = DocumentEncoder.Group3Encoding
RasterEdgeImaging Document = new RasterEdgeDocumentg();
Image. DocumentCompression(@"C:\1.pdf", "C:\2.pdf", DocumentEncoder DocumentEncoder.Group3Encoding);
I am a little confused. You mean to do compression work to  the PDF files or adjust the size of the PDF documents?
daniel147
If you feel attach a smaller size PDF file in your E-mail, there are two methods. One is to compress your PDF document and the other is to convert your PDF document to other image formats in smaller size.
longwest
Actually, different PDF converter will create different PDF size. When I want to save word to PDF. I use formats converter can get a larger PDF file, but I get a smaller pdf file when I directly save Word to PDF with microsoft office PDF converting plug-in.
I'm looking forward someone can share good resource for reducing PDF size.
11/22/2022: New firmware available for EOS R3, EOS R7 and EOS R10
10/14/2022: Help ensure your autofocus is properly aligned with a Canon Precision Alignment
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
