How do I use my MG 2570 to scan multiple pages to one pdf file?
Fanon
I need to scan multiple pages into one pdf file.
I am using MG2570, which don't have a pdf option.
Tried to use Navigator, but unable to even connect the scanner to it.
Does anyone have the same problem - a solution?
Thanks.
2 REPLIES 2
merrymary247
Rising Star
Looks like you have an Indian model, so I'm not sure if it will be the same as the US one, but with the MG2520 you would use the IJ Scan Utility instead of MP Navigator.
http://kbsupport.cusa.canon.com/system/selfservice.controller?CONFIGURATION=1011&PARTITION_ID=1&secu...
4Phoenix
I usually just regular scans one by one; I then unite all into one pdf file using nitro pdf
[link removed per forum guidelines]
Avatar
