Code 5, 156, 69
lupeta_lolo
Receiving code 5,156,69 Cannot communicate with scanner for these reasons: - Scanner is turned off. - USB cable is disconnected. Neither of these is true. I have seen that I need to turn OFF VPN, and I have turned this off, but it isn't helping. I have checked all connections and turned off and on again and downloaded the latest version of the software. HELP!
5 REPLIES 5
Moderator
Moderator
Hi, lupeta_lolo!
So that the Community can help you better, we need to know exactly which Canon product you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Patrick
Hi lupeta_lolo,
What is the model number of the Canon product that you own?
Are you using it wirelessly?
or with a USB cable?
Are you using Windows?
If not, what version of Mac OSX are you using?
Patrick,
The Model Number is: ? I'm trying to buy it from a friend and there is no listed on the machine and no box
Serial Number is: AFXN[xxxxx]
Canon Pixma MG 2522
USB cable
Windows
Into my HP Pavilion Laptop
[Serial number partially hidden to protect privacy.]
Check your firewall or security settings as well. This error can appear when the scanner driver is not being detected correctly. I would recommend reaching out to Microsoft support and they can check any security programs or your firewall to see what could be causing the scanner driver to not be detected.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well.
StuartL
Had this issue when my scanner had been working without fault.  Did everything tech support here suggested . Just installed a default windows App and guess what, scanner works perfectly. I`m using win 10 64 Bit
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
08/31/2022: New firmware version 1.1.1 is available forRF 70-200mm L IS USM
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
