03-22-2024 02:55 AM - last edited on 03-22-2024 04:01 PM by Tiffany
Microsoft Word’s page size setting is standard "letter" size (i.e. 8.50 x 11.00) in my computer, as I desire. However, when I save a Word document, the resulting measurements are 8.27 x 11.69 (metric). That's also known as "A4". Technical support tells me it's my Canon printer's fault. I doubt that, though, but I don't know how to make sure my printer's set for regular "letter" sized documents instead of metric (i.e. A4) ones. Any suggestions, please?
03-22-2024 08:11 AM
Hello!
So that the Community can help you better, we will need to know more information.
What is the exact model printer you're using (it's usually on the top or front of the unit)?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside the USA, please click HERE to find support options in your country.
Thanks and have a great day!
03-22-2024 03:12 PM
Canon Pixma: TS5100.
03-22-2024 03:15 PM
That's the series! If you look on the printer, either the front or the top you'll see the specific printer model.
03-22-2024 03:46 PM
TS5120 , perhaps?
03-22-2024 08:01 PM - edited 03-22-2024 08:07 PM
Greetings ,
I'm not sure I understand, you say that MS Word is set to 8.5x11 letter, but when you save a document in Word it saves differently. Did you mean print? Check page setup and confirm the output settings are for 8.5x11 (letter). Do this in print preview. Once you're ready to print, hold the Control key+P. Here you will be able to select the output size.
03-22-2024 11:51 PM
Hello. Thanks for the reply. I did, indeed, mean save, not print. I.e. when I save a document, either by normal saving as a .pdf document, or "printing" a .pdf to save it, the 8.5 x 11 "American" measurements morph to the A4 "metric" ones. Microsoft technical support thinks my Canon printer MIGHT be asserting a metric setting somehow. But I do not see that there is a metric setting with my Canon printer. I'd not mind but the distorted dimensions prevent acceptance when I try to e-file a .pdf document. Might anyone else here have had this sort of morphing experience? At any rate, a good weekend to all. 🙂
03-22-2024 11:52 PM
As for: "Check page setup and confirm the output settings are for 8.5x11 (letter)", are you referring to a Microsoft Word setting or one in my Canon printer somewhere?
03-23-2024 10:15 AM
I am.
Page Setup - Microsoft Support
This would be the most likely place for the issue.
Additional document settings are found in Print Preview. You may use File > Print or CTRL+P to access. This dialog let you select size, 2 sided printing, page ranges, etc. You can also click the properties menu under the printer tile at the top which opens your printer driver and displays its properties.
Print Driver Properties - This is the only place where the printer or its driver could influence page size, but it should only affect documents you are printing, not saving.
Hope one of these helps you find it.
