03-25-2018 10:02 AM
03-25-2018 10:04 AM
05-04-2018 12:22 PM
Hi Mollylathen,
Please follow these steps:
1. Turn the machine off, then unplug the power cord.
2. Pull the paper out slowly. Hold the paper with your hands, then pull the paper out slowly not to tear it.
3. Do not pull the paper out from the front tray even though you can see the jammed paper at the front tray. Pulling the paper out forcibly from the front tray may damage the machine.
4. Stand the machine with the right side facing down.
5. Push the open lever to open the transport unit. When you open the transport unit, support the machine with your hand so that it does not fall down.
6. Pull out the jammed paper slowly. When you pull the jammed paper, support the machine with your hand so that it does not fall down.
7. Close the transport unit.
8. Open the paper output cover. Remove the paper on the front tray if any. Do not touch the clear film.
9. Make sure that the jammed paper is not under the FINE cartridge holder. If the jammed paper is under the FINE cartridge holder, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper.
10. Hold the jammed paper with your hands.
11. Pull the paper slowly not to tear it, then pull the paper out.
12. Make sure that all the jammed paper is removed.
13. Plug the machine back in and turn the machine back on.
14. Reload the paper. All print jobs in the queue are canceled. Reprint if necessary.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
