Can't share the printer.
Alan1129
I have two computers in the same room.
Both are running Windows 10 and share the same internet connection wirelessly.
They are currently sharing one Canon MG2520 printer by moving the one USB cable back and forth.
I have already set up the printer as a shared device on my PC.
But when I click on Add Printer, the laptop doesn't see it .
What am I doing wrong?
6 REPLIES 6
Try searching for the computers hostname from the laptop.
\\computername\printername
~R5C (1.0.1.1) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 3080Ti FTW3 Ultra
~ImageClass MF644Cdw ~Pixel6
~6D2 (v1.1.1) retiring
How do I do that?
Alan1129
I still have the same problem.
Can anyone help, please?
Alan1129
Alan1129
The MG2520 only has a USB interface.  Its really designed to be used / connected directly to one device.  Its possible to move a USB connection between devices as well, but its not as convenient.
In a network environment, the printer  can be connected to to one computer and shared.  This allows other networked computers to print with the following limitations.  The PC the printer is connected to must be turned on for the shared printer to be accessible.
Once the printer is shared, it can be added to another machine using the add printer dialog.
Using the example I provided above.
The computer name is the "host name" of the computer the printer is physically connected to via USB.  The printer name is the share name of the printer you can specify when you enable sharing for the device.  Again, on the computer the printer is physically connected to.
Other possible solution.  Consider purchasing a true network capable printer.  You may find it more convenient  than having to deal with a USB connection, a device that always has be be powered on and the other quirks that come along with managing what is really an unreliable way to print from multiple devices.
Hope this will be helpful.
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
08/31/2022: New firmware version 1.1.1 is available forRF 70-200mm L IS USM
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
