02-24-2022 09:37 AM
I have a MG5720, with Windows 10, using the IJ Scan Utility. Magic Garden is not installed.
I want to change the location where photos are saved, but even though I made the changes in the utility, the scan program always delivers them to the desktop. I am about to scan a large amount of photos and I would really like this to work properly. Here is a screenshot of my settings.
Any suggestions? Thanks. suggestions?
02-28-2022 12:48 PM
I see the changes you made in the screen shot and that was for the auto scan feature. Just to double check, on the left side of the IJ scan Utility menu, did you select Photo Scan and set the same save location and then click save?
If you did and it does not save to downloads, which folder is it saving your photo scans to?
02-28-2022 12:48 PM
02-28-2022 02:54 PM
Okay! I always changed the setting on the little pop-up that lets me choose which scan to use. I now see that each item in the pop-up has it's own settings area. That's all needed to know. Thanks!
